Revit Lt access workshare
info
info
Can Revit Lt access or use Collaborative workshare functionality or BIM 360, to collaborate?
Elmoataz.Bellah.Salem
Revit LT don't have Worksharing features and you can see the Comparison between Revit LT and Revit  :- https://www.autodesk.com/products/revit/compare
Elmoataz Bellah Salem
AEC Technical Specialist | Autodesk Expert Elite | Autodesk Ambassador Gold Level | ACP | ACI
info
Thank-you for your post.
@info you are welcome
info
Can I ask,
With workshare using BIM 360 platform,
Is it possible for 2 or more users to open work on the same portion of an Architectural model @ the same time?
I reviewed several BIM 360 video's on the topic; they said multiple users could link to a Revit model in the Cloud and get live updates as you go. Have I understood that correctly?
@info
yes you understand correctly but i want to add something is that BIM 360 is retrieved and it became Autodesk Construction Cloud that has different modules for more info you can read Autodesk Construction Modules
and BIM 360 Design that is support Revit Cloud Work-sharing has become Autodesk BIM Collaborate Pro
and for more info BIM Collaborate Pro Features
if you have any question, feel free and ask
