Revit 2023 Docs Projects Not Showing
dmccallaENV
dmccallaENV
I am attempting to set up a new project in 2023, but the project is not appearing in the list of projects in the Autodesk Docs tab in Revit. We have several projects in 2022, and this project was started then. I am trying to create a new 2023 model in that same project, but no projects are listed in the project list. I created a new project in the construction cloud site, and that one ended up appearing in the list, but no existing projects are showing up in 2023. They appear fine in 2022. I even tried to do a complete reinstall of 2023, but that didn't seem to do anything, and I've made sure to update the most recent patch. Do only new projects appear in the list? It seems like existing projects should appear in the list in Revit.
nolangene
BIM360 projects are created for the version of the first Revit model initialized in it. If you put a 2023 Revit file in a Revit 2022 BIM360 project it will not show as a workcentral file. Only 2022 Revit files will. If you want an existing project to show up in 2023 Revit you have to upgrade it through Project Admin>Services>Upgrade Revit Cloud Models. This will upgrade the entire project and all Models contained within the project. You cannot mix Revit Versions at BIM360 or ACC. The project will only show up for the version that it is setup for. Hope that helps?
dmccallaENV
Ah! Ok that makes sense. I didn't realize the whole project structure would be based on specific Revit years. But I get it now. Thanks!
