- Mute
- Permalink
- Report
Writing an issue might be faster if all locations will be in dropdown list that contains all locations used in earlier posted issues (within the project). Plus all pre-listed locations if admin did such listing. When starting to type locations, suggestions of possible locations from the list are to be offered.
Similarly dropdown is needed for "Describe the issue or question" with few most used customisable in the settings issues list, I.e. Damage, Leak, Contamination or similar...
Idea is to save time making filling the issues faster by typing less.
Each issue should in my view get a sequential customisable identifier, so each next issue will have it's unique identifier, i.e. IS-001, IS-002, where starting part can be customized either to be initials of the person who raised it or abbreviated project name or letters combination.
Such identifiers will be useful when you will come to implement reporting of issues feature.
