Processing Failed when uploading PDFs
I'm finding that often when I attempt to upload PDFs to BIM360 Docs I get a message "Processing Failed" and the PDF does not upload, or only puts the name of the PDF onto the system (as can be seen in the images below).  Usually if I open the PDF and then print it as another PDF using a PDF printer the "printed" PDF can then be successfully uploaded. Suggestions welcomed.processing failed.png
Was this ever resolved?
Not to my knowledge
grimmbri
@Anonymous & @Anonymous, please try the solution from this article: PDF Fails to upload and giving extraction error on BIM 360 Docs
“https://damassets.autodesk.net/content/dam/autodesk/logos/autodesk-logo-primary-rgb-black-small_forum.png” >
Brianna Grimm
Global BIM Coordinator
