PowerBI.com Autodesk Data Connector
I am using Autodesk Data Connector together with Power Bi Desktop.
It works very well. I published a report on powerbi.com. He gets an error while refreshing the data.
Error occurs while authenticating with bim360dc-p-ue1.api.cosv2-p-ue1.autodesk.com. Autodesk Data Connector has been installed on the datagatway powerbi.com
Does Autodesk Data Connector work with powerbi.com?
thien.lyson
I have tested the data connector also. But it does not work.
How can I add the data connector to Power BI?
You must install Autodesk Data Connector on On-Premise data gatway. Here is the instruction https://docs.microsoft.com/en-us/power-bi/connect-data/service-gateway-custom-connectors
a.burnatniy
Hi there!
I have the same issue. Data connector works fine with Power BI Desktop.
But now I want to setup Power BI Datagateway with BIM 360 dataconnector.
I have done everything by this instruction - https://docs.microsoft.com/en-us/power-bi/connect-data/service-gateway-custom-connectors
as result I can see AutodeskDataConnector in On-premises data gateway:
and when I try to setup new data source for Power BI gateway I'm getting the following Error:
Seems that this URL is broken - https://bim360dc-p-ue1.api.cosv2-p-ue1.autodesk.com/
Any suggestions please!
I still have the same problem. The problem seems to be unresolved.
thien.lyson
I have fixed the connection between ACC and Power BI. But it's not appeared anything on the dashboard like the image below. Is it a problem with my laptop or from the connection? Please advise
