- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am having an issue with permissions when adding a team. I have folders already set up with permissions for all of the roles within BIM 360 that we use. When I go to add a team, and select the "If you have already created folders to represent teams, you can select them here." option, it changes all of the original folder permissions to almost full control and then sets all members of the new team to "Create" for their permissions. I would figure that the original folder permissions would remain and be transposed to the newly created team, not just have them all reset to a higher permission level. Any thoughts as to what is causing this, or if there is someway to have a work around?
Basically I am making a template project with folders already created with permission to save time moving forward, so if BIM 360 resets all of the permissions I have already done, it is not worth it. Thank you.
