Manage cloud models and publish setting missing
junqing.liu4PBC7
Message 1 of 14
junqing.liu4PBC7
Hello
from my revit collaborate tab, I'm missing Manage could models and publish setting button, any idea why ?
My company has ACC subscription, and I have been using ACC for a while, just noticed this problem in my Revit.
Replies (13)
Message 2 of 14
RSomppi
Those buttons won't show up if you are not in a cloud model.
Message 3 of 14
junqing.liu4PBC7
it's a cloud model, I tried it with my other desktop, it shows.
Message 4 of 14
RSomppi
Restart?
Message 5 of 14
gareth.spencer1
Hi @junqing.liu4PBC7 ,
I assume you have a license of BIM BIM Collaborate Pro assigned to you in your Autodesk account? This is your license to use the application.
Also have you activated the Revit Cloud Worksharing in your Autodesk account? You need this to use the worksharing tools in Revit.
Please click the Accept Solution button if my reply answers your question.
Twitter: @TheDarkAsset
LinkedIn: gareth-spencer-84202532
Gareth Spencer
BIM Technical Consultant | Man and Machine (UK)
Message 6 of 14
junqing.liu4PBC7
Hi @gareth.spencer1 ,
I checked my account, I think I got all..and I tried it on my other desktop, I do have the other two options, so I wonder what's hapenning ? a BUG?
Message 7 of 14
RSomppi
Restart?
Message 8 of 14
junqing.liu4PBC7
I just reinstalled Revit, and the problem went away...it's strange..
Message 9 of 14
RSomppi
I guess we'll never know if a restart/reboot would have solved the problem.
Going nuclear is always an option but if the program was working it's usually saved for later in trouble shooting. If it was a new install and there were other issues, it would higher on the list.
Message 10 of 14
KyleR13
I noticed that this has occured for me today as well with a cloud based model, but instead its the collaborate in cloud button and the manage cloud models button that are missing.  The publish settings button is available though.  I will try the restart of my pc to see if that fixes it, restarting the program did not.  I'm seeing this in Revit 2023.
Message 11 of 14
Jon
Have you figured out a solution to this?  Revit 2023 is doing the same thing to me.
Message 12 of 14
KyleR13
Jon,
  Currently the only way to publish an update to cloud models within Revit 2023, that I'm aware of is on the Autodesk Docs page and clicking the 3 dots at the end of the model row.
Message 13 of 14
Jon
I recently found that as well.  It is a good workaround, but strange that the old functionality just vanished.
Message 14 of 14
Elmoataz.Bellah.Salem
@junqing.liu4PBC7 @KyleR13 @Jon @RSomppi
I think that it is Revit 2023? if yes, you can do the same function from the home interface as following steps:-
from Autodesk Docs
Go to your Right Account and Right Project
If the model is not updated latest , you will find the Publish Latest active
Before you have to check the views and sets you want to publish
Elmoataz Bellah Salem
AEC Technical Specialist | Autodesk Expert Elite | Autodesk Ambassador Gold Level | ACP | ACI
