Identify Account Administrator for BIM360
andrew_byrne234Z4
Message 1 of 8
andrew_byrne234Z4
Community Visitor
Community Visitor
How do I identify the Account Administrator for BIM360 please?
Replies (7)
Message 2 of 8
ChitnisPrateek
Hi @andrew_byrne234Z4 please try these two links
1. https://help.autodesk.com/view/BIM360D/ENU/?guid=GUID-D2EDCF9E-4F7E-4803-A466-A377764F79E3
2. https://help.autodesk.com/view/BIM360D/ENU/?guid=BIM360D_GettingStarted_CLC_account_administrators_h...
The other place would be check is the drop down at the top left and go to Account Admin, under settings and profile all the people you see are Account Admins.
Please let me know if this works. Thank you.
Thank you.
Prateek Chitnis
BIM Manager | AECO (Buildings)
Did you find this post helpful? Feel free to click on the Like button.
Message 3 of 8
Chad-Smith
@andrew_byrne234Z4 It might help if you also mention for what purpose you need to do this.
Message 4 of 8
andrew_byrne234Z4
Community Visitor
Community Visitor
Hi Chad
We have had a lot of change in the team using the portal and nobody knows who the Account Admin is.
I am a project admin but cannot identify the Account Admin
Message 5 of 8
Chad-Smith
Gotcha. That does make sense, and unfortunately, I don't have an answer for that use case.
What @ChitnisPrateek noted above is the only way that I know how to identify Account Admins.
Your question does speak to a broader ACC problem that many users have, which is not having visibility of admins.
Members, don't have a direct line to the Project Admins are to ask for help or be removed from a project.
Project Admins, don't have a direct line to the Account Admins are to help configure projects and account settings.
Message 6 of 8
ilige_akikiAYR75
Hello, did anyone find a solution to this problem : users cannot find who is the Account Admin. And no one has access to the Admin module.
Message 7 of 8
ChitnisPrateek
Hi @ilige_akikiAYR75,
At that point, I would recommend contacting Autodesk and creating a ticket with them. They might be able to help.
Hope that helps. Please let me know if that works!
Thank you.
Prateek Chitnis
Message 8 of 8
ilige_akikiAYR75
Hi, yes that's what I did, and they managed to fix the problem. Thanks
