Federated Model (RVT,NWD)
almeidaandre
almeidaandre
Hi!
Does a .NWD file the only method to access individual links from a federated model through Docs' Model Browser?
Any other way to control individual links from a rvt file with linked rvt models?
FuldenYilmaz
Hi @almeidaandre ;
As you know, there was an upload link option in the BIM 360 Docs area, but we cannot see it in the new ACC hub. I agree with you here, unfortunately, we should only proceed with a federated model data if we have docs, and this will not be a linked model. NWD or a federated IFC may do the trick. Apart from that, if you have ABC (Autodesk BIM Collaborate) product, it is possible to view the models you have consumed and your current model directly in the system in a federated.
almeidaandre
Hi @FuldenYilmaz I managed also to upload a NWC file from Revit with all the linked files. I can access them individually through ACC 3d view model browser.
FuldenYilmaz
You are right @Anonymous , the system support to nwc files. But, Native Revit files can clash and be federated with only ABC Pro.
