Export markup comment and associated wording into an Excel Spreadsheet
michael.brandt
michael.brandt
Is there a way to export comments that are generated from the BIM 360 Docs markup tool into an Excel spreadsheet? I need the actual comment/wording (ex. "the Borrow item number should be 203211 in this schedule") along with who made the markup on the PDF found in the PLANS directory. There seems to be a way export the type of markups done by a user, but not actually the 'wording' of the comment. I need a summation of all comments and the 'wording' of each comment placed using the markup tool. I am not using Issues or Review at this time - just the markup tool.
Thank you,
Michael
renata.demuro
Autodesk Support
Autodesk Support
Hi @michael.brandt
Thank you for your post! Exporting markup comments into an Excel sheet is not possible in BIM 360. When viewing a file, there is the ability to sort by Creator name or date date created, but there is no way to export that information into an Excel sheet. This would be a great feature request to post on our BIM 360 Idea Forum! You can find more about markup capabilities here: Work with Markups
If this answers your question, please click the "Accept Solution" button so others may benefit from your post. If not, I'm here and happy to answer any questions. Thanks!
Renata DeMuro
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
tkeyser5
Is this still the case? It would be convenient to create an open issues list from the markups, without creating an actual issue for each.
