DWG file contents get exploded
Bnilath
Message 1 of 12
Bnilath
In most cases the cad file contents get exploded after being processed in BIM 360 Docs. Please, either fix this or let us know if there is any pre-requisites or best practices that we need to follow when creating cad files in order to avoid this kind of inconsistencies.
Bujair
Replies (11)
Message 2 of 12
doreen.dvoretz
Hi @Bnilath
Are you referring specifically to text within DWG files being larger / mispositioned? In your experience, is geometry affected as well?
Doreen
Message 3 of 12
Bnilath
Hi Doreen ,
It is for text only. Geometries are fine.
Thanks & Regards,
Bujair
Message 4 of 12
doreen.dvoretz
Thanks for reporting this issue.
We'll look into what's causing this.
Best Regards,
Doreen
Message 5 of 12
Bnilath
Thank you. Will wait for your response.
Message 6 of 12
Hi @Bnilath,
Could you share a sample DWF file with us?
It would be very helpful for reproducing and addressing this issue.
Doreen
Message 7 of 12
bogdan_ciobanu
Autodesk Support
Autodesk Support
@Bnilath
My name is Bogdan and I am with Autodesk Technical Support.
We will be more than happy to investigate this behavior and see what is happening. To do that, we will need your files to work directly on them.
Would it be possible for you to send them over to me? Please feel free to send a transfer link in a private message to me.
Thank you very much and I look forward to hearing back from you soon!
Best regards,
Bogdan
Bogdan Ciobanu
Message 8 of 12
Bnilath
Hi Doreen,
As requested, files shared with you. Please check and advise.
Thanks & Regards,
Bujair
Message 9 of 12
anil_mistry
Autodesk Support
Autodesk Support
Hi @Bnilath,
Thank you for sharing requested information with @doreen.dvoretz. She will do further investigation and will give you an update via Forum once she has more information.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
Message 10 of 12
doreen.dvoretz
Hi @Bnilath,
Thank you for your patience.
We've been able to reproduce the issue and investigate with the files you've shared with us. The short answer for what's happening is that the "exploding text" results from font-substitution for a missing Arial Narrow font.
Unfortunately, Microsoft has stopped including Arial Unicode MS fonts in Windows 10.
If you're running Windows 10 and you have this font installed, then it's either from an older version of Windows you've upgraded, or from an installation of some software / paid extension.
When you upload a DWG file to BIM 360, it gets processed in Autodesk's cloud service, and if the machine where it's being processed is missing a font, it would replace it with some default fallback (Simplex.shx).
Unfortunately, it seems to be outside the control of AutoCAD, BIM 360, or Autodesk, so it will be up to users to choose a different font that's available in clean version of Windows.
Here are a few additional links on the subject:
To work-around this issue, please try changing the font in the original DWG to a font that's available on a clean Windows 10 installation, and you should see the same font when you upload to BIM 360.
I hope this helps.
Best Regards,
Doreen
Message 11 of 12
anil_mistry
Autodesk Support
Autodesk Support
Hi @Bnilath,
I'm just checking in to see if you need more help with this. Did the suggestion that @doreen.dvoretz provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Message 12 of 12
anil_mistry
Autodesk Support
Autodesk Support
Hi @Bnilath,
I am checking back to see if one of the great posts in this thread helped you with your question. If so, please take a moment to reward the poster or posters with a Kudos and select the Accept as Solution button on those posts that helped.
Anil Mistry
