Does the Titleblock function recognize vertical text?
I have a structural drawing set that has the title of the sheet running vertical and it doesn't seem to recognize the text properly. Any help would be appreciated.
zijing.zhang
Hi @Anonymous,
Thanks for your feedback. Unfortunately, it doesn't support title block text in vertical orientation, but this is already on the radar of the product team.
If you have any feedback that you would like to submit regarding any enhancement, please click on the “BIM 360 IdeaStation” link on the BIM 360 community home page. This will help the Project Manager and developers hear your voice on any changes/concerns with functionality directly for consideration in future builds.
Thank you and have a great day!
Zijing
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @zijing.zhang provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I am checking back to see if one of the great posts in this thread helped you with your question. If so, please take a moment to reward the poster or posters with a Kudos and select the Accept as Solution button on those posts that helped.
Anil Mistry
I would like to point out that according to the September 20,2016 Docs Update it clearly states that,
"The September 20, 2016 BIM 360 Docs update delivers improved PDF publishing, with a new user experience for defining PDF drawing title blocks and expanded support for horizontal and vertical title blocks. "
I believe the correct solution to this question is vertical title blocks are supported.
zijing.zhang
Hi @Anonymous,
Thanks a lot for your feedback.
Currently, vertical title block is supported, but recognize title block with texts in vertical orientation which is on the road map.
Cheers,
Zijing
