Determine Project Name of Local Cache Files
dtiemeyer
Advisor Advisor
dtiemeyer
There are times when local cache folders must be deleted because a project wont sync. But if I have 10 projects in BIM360 on the same version of Revit, there are 10 folders in the cache location each with a GUID name instead of a useful name. Is there a tool or method for determining the project name from the GUID? Or a way to delete a cache folder of just a specific project from within the Revit interface?
My other CAD is a Cadillac and I like to Revit to the Max!
RSomppi
Feel free to delete all of them. It's concidered by some to clean out those foldersz on a regular basis.
dtiemeyer
That's exactly what I'm trying to avoid doing, due to the affect on model open times when a cache is deleted.
RSomppi
Sorry to hear that.
Outside of opening the local files have you looked at the previews or date modified?
dtiemeyer
Thank you Rob for those suggestions.  I've discovered something that gets me a bit closer, a file called Version.txt buried deep in the cache folders. I suppose they could be searched and the specific project cache file determined fairly easily.
C:\Users\%username%\AppData\Local\Autodesk\Revit\Autodesk Revit 2022\CollaborationCache\200703040012273\4467e257-bc7a-48a7-91f3-64b42ecc9fc0\e27883ad-67c6-49b9-883b-ee79b32b960f_backup\PermissionCache\Version.txt
