Design Collaboration can’t show the Parts.
xuwei.zuo
xuwei.zuo
I use the Create Parts to make the facade, and change the different color materials. I can see the Parts in Revit's 3D Model. But I can't see the Parts in the Design Collaboration's could model.
jens.krause
Autodesk Support
Autodesk Support
Hi @xuwei.zuo .
depending on the Design Collaboration workflows that the project admin has set up, you need to perform several steps to make changes in the Revit model "visible" in BIM 360:
  1. Make sure that the changes you made are represented in a view that is selected in the "Publish Settings" to be published to BIM 360.
  2. Sync the model with Central to make your changes available to other Revit users who collaborate on the model.
  3. Publish the latest synced model to BIM 360 to make the changes visible to BIM 360 users who cannot access Revit.
  4. If you are working with different Design Collaboration teams, the latest version might need to be "Shared" to other teams and "Consumed" by the other teams, depending on the workflows that have been set up.
I hope this helps. Please let me know if you have further questions about the above steps.
Kind regards,
Jens Krause
Autodesk Support Team
