Cleaning up duplicate companies in BIM 360 Admin
ed.bellman
ed.bellman
Prior to the "HQ" admin portal, in Field Classic account admin there was a tool to merge duplicate companies.  Is there a plan to bring this back in HQ?
patriciakeaney
Hi Ed,
Thanks for the input.  Yes, we do intend to support merging companies in the future.  This is not on the near-term (next several months) roadmap due to other urgent priorities, but we do see it as an important capability.
Pat Keaney
Patricia Keaney
Director, BIM 360 Enterprise Products
Contact Autodesk Support
anil_mistry
Autodesk Support
Autodesk Support
Hi @ed.bellman,
I'm just checking in to see if you need more help with this. Did the suggestion that @patriciakeaney provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
CharlesBerteaux
I need this functionality as well. I now have several people scattered across 2 companies with the same name (Which should not be allowed by default). when we are trying to add people to projects, there is now 2 to select and no way to tell which one is the correct one to add people to. Is this something i can put in a ticket for and ADSK can manually do on the back end???
There inst even a way to export list of people in either company to see what projects they are in to manually move to different company.
Please Advise
Charles Berteaux Iv
BIM360 + Revit Guru
Autodesk Expert Elite
Autodesk Certified Professional
“Management is, above all, a practice where art, science, and craft meet” - Henery Mintzberg
Charles Berteaux Iv
EDT BIM/VDC/Technology Department Manager | SSOE Group | Hillsboro
www.ssoe.com
CharlesBerteaux
I also thought i could just deleted the company, and then in the projects it would show them blank in whichever project they are in, but that is a no-go.
Charles Berteaux Iv
www.ssoe.com
ed.bellman
Charles,
You are experiencing the same thing I've run into.  You first have to go to each person and reassign their company on each project one at a time and only then can you delete the duplicate company.  I went through this cleaning up on some of our sister or internal companies (and ran into a couple of issues that required Autodesk Technical Support intervention) but I don't have time to go through all ~1,700 of our companies manually like that!
Sijie_Zhang
Hi @CharlesBerteaux,
A potential reason that you could not delete the company even after you have removed all the users in all projects, is if you search for this company under Account Admin - Member Directory, the company may be assigned to members as Default Company and that is probably why the company could not be deleted.
Sijie Zhang
Product Manager - BIM 360 HQ
