Can't see Element ID of object when selecting in Document Management
Message 1 of 23
Is it not possible to get the Element ID or Revit GUID to be shown as a parameter or something similar when selecting an object in 2D or 3D, while within a model in Document Management?
Replies (22)
Message 21 of 23
I would suggest using Dynamo to extract that data and adding a parameter to the elements you need.
Speed Test
Message 22 of 23
MiWolff
This is a very good contribution and a valuable hint for Autodesk. I do not dare to 'like' the original post, because I do not like what I read there at all. @Anonymous Have you filed this as an idea somewhere (ie Revit or B360 ideas)?
Message 23 of 23
loki.law.lhk
Hi Deepak, this is my situation, I tried BIM360 and ACC, but the element ID does not appear next the element name, as it does in yours, is any setting required?
