CAD dwg upload creates many documents per view
When uploading AutoCAD .dwg files we get a all of the model and sheet views, this is kind of annoying because we end up searching and deleting unnecessary views. Is there a way to choos which CAD file views to be uploaded or choose to only upload sheet views?
zijing.zhang
Hi @Anonymous,
Thanks for your posting. Currently, Docs doesn't have this kind of advanced settings in Upload flow, but we will check if there is any walk-around for your case. An update will be posted here as soon as get more details.
Zijing
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @zijing.zhang provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
zijing.zhang
Hi @Anonymous,
After investigation, we do not currently have a way to select which sheet to be published.
At this time we recommend uploading a DWG with just the desired sheets for viewing.  This can be done two different ways:
Use the layout tab context menu “Select  All Layouts” optoin to select all the layouts, unselect the layouts to be kept, then use the context menu “Delete” option to delete the selected layouts.  Save the result to new DWG.
Use EXPORTLAYOUT to make a new DWG from a layout.
Zijing
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
Anil Mistry
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I am checking back to see if one of the great posts in this thread helped you with your question. If so, please take a moment to reward the poster or posters with a Kudos and select the Accept as Solution button on those posts that helped.
Thank you and have a great day!
Anil Mistry
