Bim 360 publish model striping
ccraigUAR5X
ccraigUAR5X
I am trying to use BIM 360 to share our structural models, one issue we are ruing into is if we give 3rd party access to our doc management they get access to the full project including custom families and the engineers stamps. is there a way to limit what the 3rd party has access to though the publishing tab? I know you can select what gets published when you send a set up, is that all I need to do? Is there a way to just publish a model with nothing else attached, the main concern is the engineers stamps that show up on the sheets.
Thank you!
RSomppi
There may be better solutions but I would removed the stamps from the model and find a way to stamp the drawings only for printing purposes. That will make your engineers happy.
ccraigUAR5X
the stamps are loaded into the tittle block family as a toggle, we don't want to have to add the stamp back each time we need to send out a for construction set but also don't want access to that stamp when we are sending out coordination drawings. That is normally easy enough by just sending out PDFs with the stamp off but we ruin into the issue when we have to share models for coordination.
RSomppi
Correct.
It's quite simple really. If you don't want to share something, don't put it where people can get it. It's that or trust your consultants to play nicely.
ccraigUAR5X
edit: to correct reply
ccraigUAR5X
ok so basically there is no way to lock tittle blocks to a view only state? Or even a full project so they cant go find the stamps / families?
