BIM 360 Docs issues and future
brucegund
brucegund
Docs seems like a great tool.  I have been testing it in trial mode and am not seeing or may be not understanding the workflow correctly, (although there is very little documentation on workflow).  Some issues I have been running into
When uploaded a revit model and sheets are extracted, the sheets are not hyperlinked.  Is this supposed to happen?  Is there something that needs to be done to activate hyperlinking?
I am confused on understanding the significance and difference of Plans, Shop Drawings and Project Files.  I cannot find documentation that explains this.  Please provide.
How are Issues in Docs different that issues in Field?  Also what is the difference in Fields Library to Docs?  Could Field use Docs for it Library and link Field issues to Docs or visa versa?  Seems Autodesk could really help its customers break silos and start connecting its BIM 360 products inspiring true collaboration.
To take this further it would be great if there was a central repository for the model and sheets/drawings that are managed in one location but each of the BIM 360 products, Glue, Field, Layout, Plan (are there going to be more?) and there individual tool sets tap into the central repository.  You could also link in the A360 products as a beginning front end solution.  Finally Ops would be the final back end solution.
Will there be the ability to select the sheets out of a revit model to publish such as the Collaboration for Revit tool provides?
Guess that is all for now.
ilai_rotbaein
Hi Bruce,
Thank you for sharing your feedback with us. While I'm happy to hear you're excited about Docs, I have to say that I agree with you there are certain gaps that we need to close in order to make it a truly awesome and productive tool. The good news are that we're doing exactly that and the things you have mentioned on your comment are indeed in our roadmap so stay tuned..
We will be creating a more integrated experience between Docs, Field and Glue so that issues for example could be easily share between those. I think your comments are spot on and will be addressed.
For more information on the difference between shop drawings/Plans vs. other folders, please check out this thread.
Ilai Rotbaein
BIM 360 Team
To Whom Can Answer This :),
So it's 05-2019 and I don't see that this problem has been fixed. I could be totally wrong, so please correct me if I am.
But are issues in Docs being linked into Field?
Are the photos in Docs getting linked into the Field Library?
Again, please let me know if there is a way to do this. I really would appreciate it 🙂
Thank you!
