Best way to capture as-built / as-constructed information
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm wanting to use Field to capture as-constructed information. My example is a concrete box,, made from precast concrete walls, columns, beams and roof panels. These arrive on site with a unique code from the supplier, say ABCD. I want to match these with the model, which has a different unique code, say 1234. I want to capture the supplier's code, the date installed, plus some other data. If I do this on a checklist, is there a way of linking that to the model, other than manually interrogating it and typing the code in? If I do as an issue, I have to go into the model first, to add the pin, but the issue form doesn't let me enter the data I want. A photo (on the issue) helps, as this could be taken of the code/delivery note of the product, then because it's an issue at least it's 'tagged' to the model element. Ultimately I want to know that ABCD = 1234. Maybe a markup is a better method?
Is there a better workflow I should be using for this sort of thing?
