Autodesk Docs
Autodesk Docs
rgettlerPHB
Autodesk Docs
rgettlerPHB
We have a project where all members are using Autodesk Docs to store .nwc files for the project and we append the files into Navis using desktop connector. When everyone currently makes new .nwc files and myself also,  when I go to refresh my Navis model why is my file the only that refreshes in model? If I shut down the model and then open it up then everyone's changes are shown.
HGC-Jchandler
@rgettlerPHB A work around for this issue may be to setup a coordination space in Docs, setup a view or views with your .nwc files and then open those views in Navisworks through the coordination tab rather than linking through the desktop connector. An added benefit to this approach is you'll then have access to coordination issues as well.
