Accdocs File Sync Issue
ramesh.miryala
ramesh.miryala
Drawing files which are saved by me are uploading to ACCdocs & updating in the server.
Tricky part is those files were showing 1 kb to me not syncing from server to my system, Unable to open those files later as the file size was 1kb.
In Accdocs file was good to open..!
Yoshiyuki_Miyauchi
@ramesh.miryala
If you experience problems with synchronization, check the following sites
https://health.autodesk.com/
If you are not experiencing problems with the ⇑ site in particular, then you have a problem with your wifi connection speed or the amount of file data.
Please click the Accept Solution button if my reply answers your question.
こちらの投稿は役に立ちましたか?良ければ「いいね」お願い致します!
こちらの投稿があなたの問題解決に寄与した場合、「解決策として承認」ボタンのクリックへのご協力をお願い致します。
Yoshiyuki Miyauchi / 宮内よしゆき
openBIM Architect
ONESTRUCTION Inc. Co-Founder & CTO
buildingSMART Japan IFC利用支援小委員会 委員長
bSI BIM Professional Certification | BSI BIM Project Information PRACTITIONER | BSI BIM Asset Information PRACTITIONER
Civil User Group認定インストラクター
y.miyauchi@onestruction.com | TEL:050-3528-8052
Twitter|LinkdIn
