ACC and Desktop Connector are a joke
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
In the past, I had used other cloud services like ProCore and Fieldwire. I never had an issue seeing information on Desktop PCs and platforms.
1. ACC Docs and Desktop Connector don't sync. If I upload to the Cloud using the Cloud when I see it on the Cloud but not on the PC and vice versa.
2. It makes duplication, which I didn't duplicate
3. It says the file is locked but actually doesn't show what is locked on ACC Docs. There is no way to unlock it, and you can't save it to the Cloud.
I am only using ACC Doc, and I am the admin. I work mostly with Revit and Fusion and sometimes with AutoCAD.
The point is. The Desktop Connector should be the number 1 priority because it is a bridge between the Cloud and the desktop PC if the desktop connector fails when the Cloud fails.
I tried to communicate with support, but the way they approached it was a complete waste of time for customers with emails. Instead, they connect remotely, see with their own eyes, and decide. I am sorry, but the support team is unprofessional, and they are circling around instead of helping to find a solution.
The customer support team thinks that we don't have jobs, we are testers for the Autodesk Developer department, and that project setup is an optional part of the construction. The customer support team don't value customer time.
This is a problem with the Cloud and Desktop Connector support team.
Revit support team engages with customers directly and solves and looks at problems using a remote desktop. It saves a lot of time because they are cracking on the go.
Kind regards,
Robertas
