2D Revit Sheets - Version Compare ?
Steve_Th
Steve_Th
I can compare 2 different Revit Sheets. I can also compare versions of a Revit Model. Can we not also compare 2D Versions of the same Revit Sheet?
doreen.dvoretz
Hi Steve,
Yes. From the document picking view, click on the version number next to the sheet's name, and then click the "Compare Versions" button.
We plan to make all comparison options available soon from the document viewer as well.
Best Regards,
Doreen
anil_mistry
Autodesk Support
Autodesk Support
Hi @Steve_Th,
I'm just checking in to see if you need more help with this. Did the suggestion that @doreen.dvoretz provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
Steve_Th
Thanks, Doreen & Anil,
I hadn't realized the other way this could be done. I look forward to the locations of the features being coordinated over time.
anil_mistry
Autodesk Support
Autodesk Support
Hi @Steve_Th,
Thank you for your reply and I am glad to hear that the issue is now resolved.Please, let me know if you have any other questions or concerns.
Thank you and have a great day!
Anil Mistry
