Reopen ignored clashes automatically after Objects change (Model Coordination)
When a Clash is set to "ignored" it stays in this status until a user set it back in an aktiv status. So if the Modell changes, this clash does not reopen. This can cause Problems because a ignored Clash of 2mm kann be a big clash in cm-Spaces after the Objects has been changed. So the Clash should be reopened automatically.  If don't, there is not only the Problem of not recognizing the bigger clash but that you can only check the situations after manually reopen the Clash. That is far from user-frindly an is a potetially source of error.
3 Comments
nenad.milinkovic
+1
Justin_Quarters
If it is a new object, it should be creating new clashes anyways. The closed issues should be reviewed periodically by a BIM Coordinator to determine if it needs to be revisited. Detailed ignore reasons and comments will be the most important part contributed by the one who ignored the clash. Reopening automatically would create enormous amounts of redundant work.
Maybe a better route would be to provide an option to reopen or keep them closed when new versions are uploaded.
Or an alert when clash tolerances change in ignored/closed clashes.
Technology Administrators
