Possible to change the Viewer back to IFC properties
Dear Autodesk,
When using the viewer in BIM360 Docs and Glue it only shows me the Revit properties instead of the IFC properties when opening an IFC. Also when I have the workflow Revit to IFC > IFC upload to Glue > Navisworks getting the IFC model from Glue all of my IFC properties are turned back into Revit IFC properties. Even when in Navisworks I unchecked the Revit IFC in the options. Please Autodesk Revit IFC doesn't exist. It ruines the IFC structure.
IFC is the openbim standard for all of us. In the Netherlands we have to do checks on IFC properties as an standard for the Dutch Government BIM protocol and Basic IDM.  With this Revit IFC when cannot do our checks correctly anymore. Simply said as before Revit IFC is not an IFC. It is an IFC turned back into a Revit model!!
Make it possible to change the Viewer that is used in Glue and Docs back to an IFC viewer. Without transforming my data back to Revit.
In the attachments the first 2 screenshots are IFC models taken form Glue or opend in Navisworks from Glue.
The third one is the way we used to read IFC files.
2 Comments
thomaskoruga
To expand on this idea:
We are experiencing the same issue: There are parameters in the IFC file / DWG file / DGN file which are currently accessible in Navisworks but are not accessible from BIM 360.
Please enable us to view all parameters from DWG files and IFC files in BIM 360.
bas_van_berkum
Community Visitor
Still a problem with the change of parametergroups and parameter names.
