mass upload
mass upload
I want to be able to drag and drop a top-level folder with multiple files and subfolders into the ACC Docs HTML interface.  Currently, you can only drag/drop files (not folders/subfolders).  This should be a basic feature.  Box, Dropbox, etc. can do this.  As it stands, I have to use File Explorer and ADC to accomplish this function.  Using this alternate method doesn't work because ADC locks up and doesn't process all of the files/folders/subfolders.  I have to return to the ACC Docs portal to verify the successful upload.
Being able to drag/drop an entire top-level folder with data within will make uploading bulk data much easier.  For example, if you have a server with data separated into years (2008, 2009, etc.) and there are multiple projects/files/folders contained, you can just drag/drop the 2008 year folder into ACC Docs from html and it just uploads the data...
