Linking pushpin location paths from Field to Glue
When using Models to add issues to a project, the location in the model has to be manually entered even when you are within a level/room of a 3D model. Thus when you print your issue report to PDF, the location description is always blank, and you do not get an image of the pushpin location - making the PDF report useless if the location hasn't been manually entered for every issue.
It would be useful to be able to link your location paths to rooms of a 3D model rather than just the 2D floor plan.
