I am logging this on behalf of a customer.
The designed behavior is that when an issue is selected from the issues module - it loads only the single model that the issue was tagged to in the BIM 360 viewer. When the issue is created in Model Coordination, clicking on it again in the issues list in the issues module will NOT load up the viewer as it was in the Model Coordination service when the issue was selected (with multiple models loaded up).
The EP customer at Perkins & Will would like to request a feature improvement that would allow the issue to be loaded up in the viewer in Model Coordination and would display the hosting model (of the offending element causing the clash issue) and the model it was clashing against (the original view when the issue pin was dropped into the model) when clicking on the issue from the Issues list.
Thank you,
-Scott
