Filtering Modified 'data' for Visualisation (when comparing changes)
The idea has come about from this situation. I have previously uploaded a model to the BIM 360 platform (Design Collaboration) - where some COBie data had been added (prior) to this along with a full model upload. This was at the point where small design changes were still being implemented. So the architect makes a change to a toilet area or two, which as MEP designers we capture. At this point I re-run a COBie update to the objects with adding some more data, and publish and share this once the update's carried out. However, now with using the change visualisation when sharing the package - EVERYTHING has been modified, both data and object properties. My idea is - can we workset/specify what we can see as a 'change'? i.e. COBie.Nominal.Width, COBie.Nominal.Height & COBie.Nominal.Length fall under one group to check, whilst COBie.Type.Description and COBie.Type.ModelReference fall within another (which is specified at the project outset in the background for the visualisation to check).
