There is a need to be able to quickly and easily append hyperlinks onto "equipment" within 360.
There should be a way to export all equipment into a spreadsheet and then fill out the "attachment" column with links tab-delimited or similar. Then upload/import this dataset into the software.
This could either be initially added within Navisworks on the back of each element or added in 360. Either way using said spreadsheet or similar.
Currently, every equipment item needs a lot of time and effort investing in it.
