Edit existing roles
Edit existing roles
Currently if you want to edit, rephrase or rename a role you need to create a new role and then change your use from Role "A" to Role "B", which would in turn break any role based permissions currently set. Sometimes you just want to rename Role "A" to Role "B" and maintain all existing permissions.
3 Comments
JeremyWeber-NSPJ
This is much needed. If multiple projects are in place when a role needs to be changed, creating new roles and going back into each project to update permissions is a nightmare.
johan_van_mol
This is a duplicate of Rename role - Autodesk Community
JeremyWeber-NSPJ
Yes it is, and Autodesk hasn't gone through to cleanup and consolidate.
