The package control sharing needs improvement. Imagine the following scenario where you want control (highly-restricted) content. Say you want to share it with your design team but not in the default ‘shared’ folder. This would allow the design team access to all the information to allow progression of the design, while restricting certain views for security reasons. At the moment all published views are being shared – regardless if you add it to the package or not.
Below a detailed steps explaining the issue
- Enabled BIM360 (Restricted) set in Publish settings
- Views as on screenshot
- Enabled BIM360 (Highly Restricted) set in Publish settings
- contains additional views 04- Fire, 06-Security only
- Synchronised and published
- Go to Design Collaboration and create a new package
- Select only BIM360 (Restricted) set
- the BIM360 (Highly-Restricted) package is not selected
- Save and share package
- Now I expect to see:
- In …\Project Files\01-M3-WES (Elec) – I expect to see all views/sets
- In …\Project Files\Shared\01-M3-WES (Elec) – I expect to see only the restricted set
- What I see instead is all views – both sets restricted and highly-restricted – even though I didn’t share the highly-restricted
Now all people with access to shared folders have visibility to the content which was not shared with them. What I am saying is that during the creation of the package the selection of sets does not work.
Although the response from Autodesk hep is:
…’This is working "as designed". Currently, all views are extracted from the model and are available in docs. The selection of the view sets is only respected inside Design Collaboration. Hence publishing only selected views is the only option. Please let me know if you have more questions for me on this. ‘…
