Some points i raised about Autodesk Docs as cases for Autodesk team but was never solved ! :
- hyper-links not active in issue description and response parameter is missing (Case Number 01551634).
- over due dates in issues not appearing as red color (Case Number 01551688).
- Project activity log not showing in ACC [CaseNo:18434946.].
- Issue column attribute not showing in ACC [CaseNo:18434940.].
Also please note that all this faults are in Autodesk docs. although it was present in BIM360 docs and they worked just fine.
Autodesk docs. should keep the good interfaces of BIM360 docs and update it, not delete all these features !
