BIM DOCs Approvals Workflow
Key functionality of a document management system is to have drawings that have gone through the correct Approvals before they can be used.
BIM Docs needs to have a formal Approval function. This would be similar to the RFI function. You must be able to create simple workflows, these workflows could then be saved so if you are on a Design and Build contract or a Traditional contract then you would have different workflows set up. Once drawings are uploaded onto BIM Doc they could then go through the formal process of getting Approved by all the necessary organisations. This is at a minimum what i would expect.
Advanced. As BIM Doc's is a new smart system I think we this should just not be like all the rest of the Doc Management systems but should be  a clever system, I would like to have
  1. A running commentary at both a drawing level and a Work Package level.
  2. Built in checklists for each drawing, these checklists would cover a whole range of items that the that are saved in templates that can be assigned to a drawing or package of drawings.
  3. Multiple approvals per drawing and a visual indication on which drawings are approved or not
  4. Automated workflows with email notifications and a dashboard. If an organisation is not approving documents in a timely fashion then they should get an email notification, there should also be a dashboard showing status and progress of drawing  and packages of drawings for approval.
  5. Built in Intelligence, so not being able to approve drawings for construction if the still have outstanding RFIs attached to them or automatically removing approval status if drawings are updated, etc...
7 Comments
joan_allen
joan_allen
Status changed to: Accepted
Hi - we released the first version of the review and approval workflow feature in November, and have continued to update it regularly.  Here's what has been included in each release:
http://blogs.autodesk.com/bim360-release-notes/2018/11/07/bim-360-docs-update-november-7-2018/
http://blogs.autodesk.com/bim360-release-notes/2018/11/29/bim-360-docs-update-november-28-2018/
http://blogs.autodesk.com/bim360-release-notes/2018/12/13/bim-360-docs-update-december-13-2018/
We plan to add more capabilities in the future, and we welcome your feedback.
Best Regards,
Joan Allen
Autodesk BIM 360
Great post. We are struggling exactly with same issues.
In addition to all said above, I suggest to create a digital stamp ability for an official approval process (such a stamp of a firm for the permit application sets).
adam.bear
We currently use meridian for our traditional CAD projects and our working on using Docs for BIM projects. I'd like to get my entire organisation to use Docs - but there is resistance that Docs does not match the functionality of meridian in being able to update a title block with an approval status, without a user having to manually edit a drawing
penny_yu
@adam.bear Thank you very much for your idea. By " update a title block" do you mean adding stamp or text on the sheets?
Best Regards
Penny Yu
BIM 360 Document management
adam.bear
Hi Penny,
Not so much a stamp, that could be a step in the right direction, but not really what I was referring to in the features of Meridian which updates the attribute values of a block 'titleblock' for multiple batch drawings from the meridian user interface. I've pasted the below from the link below
https://docplayer.net/14682526-Bluecielo-meridian-enterprise-key-capabilities.html
3.6.1 AutoCAD Integration (and DWG-based CAD Files)
BlueCielo Meridian supports Bi-directional Title Block integration, which means that values of properties changed in the title block are updated in the BlueCielo Meridian vault and vice versa. This can be fully automatic or controlled through configuration (only at save, from file to vault only or from vault to file only, for certain users only, etc.).
Many Thanks
adam
penny_yu
@adam.bear Thank you for the detailed explanation!
Penny
