Show only
Search instead for
Enable import / export (to excel) of users to make the project management easier. When working with a lot of projects the user / team member management has still a lot of room for enhancement at project level.
Not just users, projects and content across a hub. We had an outage today where folders and files were loading with missing content or garbage file names (hash) and I had no way to see what content was in the BIM 360 Team & Docs Hubs. Would like to be able to export a coherent spreadsheet with users, projects and project content at a hub level.
It is borderline negligent that importing users isn't supported yet. Currently you can paste a list of 30-40 users into the 'Add User' dialog and give them all the same role (Subcontractor for example), so you can import your Subs, Architects, and Owners etc. in separate sets. But once they are all in there you still need to click on each user to give them a Company and also assign them 'Build' access (which should be automatic, or a setting to make it automatic). I also don't believe that the Auto license assignment works perfectly every time.
With a simple Excel or CSV import I should be able add users and assign their role, company, access level, and give them access to modules in one step.
