I believe that Autodesk Desktop Connector, tool that connects your cloud data with local space needs vast improvements. The way that it is structured now makes a lot of problems in correct workflow online-offline. And all major cloud worksharing apps (google drive, dropbox, onedrive, box,...) are vastly better to work with data and properly syncing them.
Autodesk Desktop app doesn't store the data but compares data that are cached (different local path) and cloud. So if you work on Plant cloud project on Revit cloud file, etc... and if on the SAME pc you want to use the "local" version. You have to publish it on cloud, Sync it (download) to desktop connector and than you can use it. Because of the different paths.
For some apps (Plant) there are even different files at Desktop connector and cache (DCF files, ...). So its is not 1:1 copy.
Take inspiration from your own Autodesk PDM - Autodesk Vault.
I am sorry but even simple "Synology app" for syncing files is better at this workflow than Autodesk Desktop connector. Which is aimed at CAD files. True. But have a lot of things to learn. If you agree, please vote for this idea.Thx
¿No encontraste lo que buscabas? Pregúntale a la comunidad o comparte tus conocimientos.
