Autodesk Construction Docs/ aka BIM 360 Local File API
Revit third-party apps do not have methods to get the file state of local ACCDocs/BIM 360 files and deterministically
force the download of a current version from the cloud. With the lack of an Autodesk sanctioned solution, it is difficult to use ACCDocs/ BIM 360 for all collaboration needs. These are just examples of a few of the API functions we would need to better serve our customers:
- static class BIM360FileUtils
- void GetFile(string filepath)
- enum FileStatus
- string GetFileStatusDescription(FileStatus status)
- int GetFileLocalVersion(string filepath)
5 Comments
Thanks for the answer.
Good WE
Rouben
Not just Revit, any of the modern Autodesk apps that have a publish or sync or whatever collaboration use the connector.  If I wanted to provide a similar function for any other product to get data into BIM 360 or ACC I'd like to use the connector to do so.
rwtaylor_revit
This API access is critical for third party applications when Autodesk makes changes to the Desktop Connector as they have done with version  v16.0.0.1902
rwtaylor_revit_BOS
Community Visitor
Asking for this again almost 2 years later.   It's still a requested need.
moogalm
Autodesk Support
Hi all,
Wow — 121 votes and counting! This clearly highlights strong community interest.
Could this request please be brought to the attention of the Desktop Connector team?
Providing a Desktop Connector API would enable third-party developers to programmatically access critical details such as:
  • File state (local vs. cloud)
  • Hub and project information
  • Sync status and versioning
This capability is essential for building reliable tools that integrate with Autodesk Construction Cloud (ACC) and BIM 360 workflows, especially as the Desktop Connector evolves.
Thanks!
https://portal.productboard.com/6trthklkv1qn3pgqk8hfwhk2/tabs/33-under-consideration
