Meetings are great and easy to use.
Now when your in a meeting you can add notes either under the items or in the meeting summary, which is straightforward. If you add an item you can only assign the item status and assign actions, set due date or reference files to the item.
In some cases you might have multiple actions added to an item which you need to assign them to different members. Let say in this case they are outstanding RFI's (as shown in the below image) you can only assign them to the item.
It would be great if we could add individual actions against an item to assign due date, member, attachments, and references. Then status can be applied to close out as the follow-up meetings continue.
