ACC and AutoCAD attribute mapping
ACC and AutoCAD attribute mapping doesn't exist!
  • Attribute mapping between ACC and all Desktop App like AutoCAD, Architecture and AutoCAD Plant 3D doesn’t work!
  • Bidirectional update of Attribute mapping (changes on both sides get synchronized)
  • Double maintenance of attribute
Example:
If you are a modern company, you would have a general Title block (Drawing head) on each Drawing! This is a must for each drawing which you send to fabrication or Customer and so on.
Now my question: How you manage this attribute if you create thousand off Drawing on ACC? Did you type in Name, Date, Contractor, Owner, status, revision and so on one by one and manual on each drawing? Is this not tedious, time consuming? It's this the quality and efficient which you really want!
  • On AutoCAD you have the option to synchronies the attribute with each modern PDM-, PLM-, DMS-System exclude ACC (This attribute sync is a state-of-the-art function which each modern system provides).michaelbroennimann_2-1677571347563.png
  • On ACC no mapping for the fields between AutoCAD attributes. I need to type in the same information again and again LOL.
We would like to have the attribute mapping between ACC and Autodesk Desktop Apps to improve our efficiencies and quality!
Regards
Michael
1 Comment
jeamy.baena
Actually, This feature and metadata from documents (word, excel...) are already supported in Vault Professional. ACC team: look this application that have a very useful related functions to implement in Autodesk Docs. For example: life cycle states engine for files with dynamic permissions..
