Problem Loading File ( is it due to file size)
I have problem loading the naviswork file in Bim Glue 360.
How big the file size can be uploaded in the Bim Glue 360.
i use naviswork because the revit file is much bigger, about 200mb
frederick.regala
Hi Nino,
Thank you for your post.
At what point of the upload does the error message pop up?  Does it go through the upload or does it fail while uploading?  Glue is capable of handling large files, the file size becomes a factor if the bandwidth or connection is slower.  If the failure happens while the model is being processed  in Glue then it may be a different issue.
Which file format were you trying to upload?  Were you using the plug-in from Revit?
Thank you!
Frederick
Frederick Regala
Deployment Specialist - ELearning Content Creator
Autodesk Construction Solutions
Hi Frederick,
after loading about 30 - 40 min, the message suddelny pop out, so i cannot say wherether it finish the loading or it is halfway through.
by the way im loading Naviswork Document because of my native file in revit have more bigger file size.
the naviswork file is about 220mb.
Thanks and regards
Nino Abunda
frederick.regala
Hi Nino,
Thank you for providing additional information.  We are actually investigating an issue with uploading large NWD files which we should resolve very soon.
Although uploading an NWD file is an available option, I would still recommend that you try to upload views from Revit.  Unlike the other applications wherein you are uploading the entire file in Revit, it is a bit different for Revit.  Only views are uploaded in from Revit and not the entire Revit file.  Views can be uploaded in NWC or DWF format which will be much smaller than the total file size of the Revit file.  One of the primary advantage of uploading views directly from Revit is it makes it easier to update the models in Glue if there are updates to the Revit file.  It eliminates extra steps.
I hope this information helps.
Frederick
Frederick Regala
Hi Frederick,
Following your recomendation using revit's addin to export the file in BIM glue 360, im still having problem loading the file
Thanks for the recommendation but we still prefer the NWD. Please advice if the problem in loading the NWD file is resolve.
Thanks and regards.
Nino Abunda
