- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
For more than a week now Glue has stopped working.
It hangs at the startup page:
No errors no messages.
I have tried to install it from here:
https://b4.autodesk.com/BIM360Glue64bit/setup.exe
and I get "URLDownloadToCacheFile failed with HRESULT '-2146697208'"
Full log:
The following properties have been set:
Property: [AdminUser] = true {boolean}
Property: [InstallMode] = HomeSite {string}
Property: [NTProductType] = 1 {int}
Property: [ProcessorArchitecture] = AMD64 {string}
Property: [VersionNT] = 6.1.1 {version}
Running checks for package 'Microsoft .NET Framework 4.5', phase BuildList
Reading value 'Version' of registry key 'HKLM\Software\Microsoft\NET Framework Setup\NDP\v4\Full'
Read string value '4.6.00081'
Setting value '4.6.00081 {string}' for property 'DotNet45Full_TargetVersion'
The following properties have been set for package 'Microsoft .NET Framework 4.5':
Property: [DotNet45Full_TargetVersion] = 4.6.00081 {string}
Running checks for command 'DotNetFX45\dotNetFx45_Full_x86_x64.exe'
Result of running operator 'ValueEqualTo' on property 'InstallMode' and value 'HomeSite': true
Result of checks for command 'DotNetFX45\dotNetFx45_Full_x86_x64.exe' is 'Bypass'
Running checks for command 'DotNetFX45\dotNetFx45_Full_setup.exe'
Result of running operator 'ValueNotEqualTo' on property 'InstallMode' and value 'HomeSite': false
Result of running operator 'VersionGreaterThanOrEqualTo' on property 'DotNet45Full_TargetVersion' and value '4.5.50709': true
Result of checks for command 'DotNetFX45\dotNetFx45_Full_setup.exe' is 'Bypass'
'Microsoft .NET Framework 4.5' RunCheck result: No Install Needed
Launching Application.
Error: An error occurred trying to download 'https://b4.autodesk.com/BIM360Glue64bit/BIM360Glue.application'.
Any ideas on how to solve this?
blog.ads-sol.com
AIP2012-2020 i7 6700k AMD R9 370
Did you find this reply helpful ?
If so please use the Accepted Solutions or Like button - Thank you!
