what is the difference between BIM 360 Field and BIM 360 Build ?
Message 1 of 9
Hi
I cannot find Bim 360 field product no longer on Autodesk website!!!!
What happend?
My license is expired and i don't know what should I do
Replies (8)
Message 2 of 9
bogdan_ciobanu
Autodesk Support
Autodesk Support
@Anonymous
And thank you for your post. My name is Bogdan and I am with Autodesk Technical Support.
BIM 360 Build is a package that includes: Document Management, Project Management, Field Management, Insight, Project Administration and Account Administration and BIM 360 Field.
So, in other words, BIM 360 Field (classic) is no longer sold separately, but in a package with the next generation BIM 360 products.
I hope this was helpful.
If my post answered your question, thank you for accepting it as a solution so that other community members can find it easily and use it if they have the same issue.
Best regards,
Bogdan
Bogdan Ciobanu
Message 3 of 9
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @bogdan_ciobanu provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
Message 4 of 9
IBM 360 build is an package which includes  document management, project management.
IBM 360 Field insight a project administration and project administration.
Message 5 of 9
Hi Bodgan
Thanks for helping me, your reply is great , but i have other questions:
what will happen to my documents in BIM 360 Field ? can I have access to them ?  are they stored some where ?
Message 6 of 9
Hi, Bogdan!
Example: my collegue use BIM 360 BUILD, could I get data of Field Managment if I use BIM 360 DOCS or I need BIM 360 BUILD too?
Message 7 of 9
bogdan_ciobanu
Autodesk Support
Autodesk Support
Hi @Anonymous,
To get access to your colleague's BIM 360 Field Management project, they will need to invite you to their project and you will use one seat from their account. You cannot access other people's projects with your own seats.
Also, if on a project there are multiple services activated, for example, Field Management and Docs, and you are only invited to Docs, you will not be able to see the information from Field Management. You need to be invited to each service to see what's happening in that area of the project.
Hope this helps.
Best regards,
Bogdan
Bogdan Ciobanu
Message 8 of 9
Thank you!
It was very helpful!
Message 9 of 9
Hello everybody,
I'm searching for a trial version of BIM360 Build, but when I click on "start a trial", a page of  BIM360 field free trial appears instead of BIM360 build.
Anyone can help me finding the right start a free trial of BIM360 Build page?
Thank you!
Carlo
