iPad app crashes when selecting issues from menu
We have had numerous users reporting that their BIM 360 Field iPad app crashes upon selecting issues from the menu. All other menu options are fine.
Is this a known error? Is there a fix for this?
It occurs due to some junk information.
patrick.beattie
Hi @Anonymous,
Thank you for posting to the BIM 360 Field forum.  The behavior you are seeing has been submitted to the development team.  An improvement is expected within an upcoming BIM 360 Field iOS release to prevent this behavior.
A potential workaround until the improvement is released is to create saved filters that have search criteria based on the Author values you need access.
Let us know if you have any questions.  If this answers your post, please choose Accept as Solution so that other members could see the answer as well.
Best regards,
Patrick B.
Global Product Support
anil_mistry
Autodesk Support
Autodesk Support
Hi @Anonymous,
I'm just checking in to see if you need more help with this. Did the suggestion that @patrick.beattie provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
