sorting issue in BIM 360 Field
My experience is similar. There is typically an option to click the header of a given column, and the system will sort the list according to that column. It is indicated by a small triangular arrow sorting in either ascending or descinding order. This arrow has disappeared and now I am unable to sort by the various categories (date, Issue ID, etc.).Please advise.
I have the same issue. Did anyone ever provide a solution to this?
Luciane_Conceicao
Autodesk Support
Autodesk Support
Thanks for your post.
I can see that the arrow has disappeared, but if I click the top right corner of the column name, then it appears and can be used.
Does this help?
I am using Chrome.
Cheers,
Luciane
Luciane Conceição Taylor
Product Support Specialist
Autodesk, Inc.
Please click the button "Accept Solution" if this suggestion resolves your issue.
Autodesk, Inc.
