Problem synching solved issues
there is a problem in one of our Field projects that after synching the information on the iPad to the cloud, some closed issues fail to sync and turn back to open. This problem occured when normal synch was not working and the resynch all option was applied.
with best regrds,
Ilari Kärkkäinen
Skanska Oy
don_simpson
Hello Ilari,
I see that a support case has been generated from your forum post and that a specialist is working with you directly.
Don
Don Simpson
Technical Support
