Issues with running reports
plucasLDBMN
plucasLDBMN
I am having several issues..
-When running a issues report only a handful of items appear when running the report. I have 50 punch items.
-The pics do not show up when I run a report
-I work for a large GC that has an enterprise account with you yet I don't get phone or email support because I'm a non-subscriber? Interesting...
don_simpson
Hello plucasLDBMN,
Thank you for contacting Autodesk.
I will send a direct message to you, as well.
Below are some initial thoughts regarding your reporting issues.
Are you selecting a saved filter option from within the "Filter" drop-down list when selecting the report parameters?
- This is not a required parameter and would limit to report to a maximum number of issues that the saved filter within the issues area would return.
- If you are adding other parameters, this would limit the report further.
Within the report parameters under "Extras", are you selecting a value from the "Show attachments" drop-down list?
- Reports would otherwise default to "Don't show attachments" and would not generate images.
- You can further select size of the images that generate on the report: small, medium, or large.
If you are looking to see pushpins, that also would not show on the report by default. There is a separate "Pushpins" parameter, also under "Extras".
Please let me know if this helps.
Don
Don Simpson
Technical Support
anil_mistry
Autodesk Support
Autodesk Support
Hi @plucasLDBMN,
I'm just checking in to see if you need more help with this. Did the suggestion that @don_simpson provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
anil_mistry
Autodesk Support
Autodesk Support
Hi @plucasLDBMN,
I am checking back to see if one of the great posts in this thread helped you with your question. If so, please take a moment to reward the poster or posters with a Kudos and select the Accept as Solution button on those posts that helped.
Thank you and have a great day!
Anil Mistry
plucasLDBMN
yes this answered my question. Thanks.
I am having a second issue however. When new issues are created, they disappear off the ipad when synced, except 5 issues marked as void. How do I sync so that all the issues on the bim 360 desktop also appear on the ipad?
don_simpson
Hello plucasLDBMN,
I moved your later post after the most recent post still present in this thread to a new forum post: Sync is skipping issues. Both issues are likely either related to the issues sync setting that is selected on the iPad and/or possibly the saved filter parameters of the sync setting that has been selected. Please review the new thread and post any follow-up questions that you have there.
Don
Don Simpson
Technical Support
patrickthompson2B2FY
Community Visitor
Community Visitor
Hi, has this feature to export pushpins, and change the size of the image been removed?
