How to associate a location / push pin in a document in the library for an issue
Siva_T
Message 1 of 8
Siva_T
Is it possible to view and download older versions of document in library?
Siva
Replies (7)
Message 2 of 8
s.odwyer
Yes all documents uploaded can be accessed. This is only through the correct allocated permissions.
Your title and question are different.
Regarding the title you can associate locations and pins to any issue.
Sean
Message 3 of 8
Siva_T
Thanks Sean for the reply. Somehow the subject text got messed up that I didn't notice. My question is regarding, managing the versions of drawings in BIM 360 Field. While you can see that there are different versions, are you able to download an older version or view an older version? It seems it shows only a thumbnail preview of the older versions.
Siva
Message 4 of 8
s.odwyer
Hi Siva.
If there are versions on field you can access and download them. It is what bim360 is built for.
Sean
Message 5 of 8
Siva_T
Hi Sean, thanks for your reply. Could you please give the steps to view and
download older versions. I am not able to find it on a first look.
Siva
Message 6 of 8
s.odwyer
Hi Siva,
Only getting to it now. Sorry.
If you go to the library and exit the library previewer. Then navigate to the relevant file. if you select the file you have you can revert back an version you want. Then click on the view tab on the top left. This will open up the previous document.
Hope this helps.
Sean
Message 7 of 8
anil_mistry
Autodesk Support
Autodesk Support
Hi @Siva_T,
I'm just checking in to see if you need more help with this. Did the suggestion that @s.odwyer provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Thank you and have a great day!
Anil Mistry
Technical Support Specialist
Message 8 of 8
Siva_T
Thanks Sean. This is good info. Thanks for taking time to explain this.
Siva
