BIM 360 FIELD MANAGEMENT ADD LOCATIONS
laura.smithPBW52
laura.smithPBW52
Is there a way to automate locations or import locations? Adding adding 12 levels plus 20 plus room each level is time consuming. There has to be a better way to automate this process.
don_simpson
Hello laura.smithPBW52,
The Help article To Add Locations To a Project provides steps to create location both manually and through a Excel import.
If you have access to developer resources, there is also a BIM 360 Field API that can be configured to upload data into the application. This is most frequently used to upload documents into the project library, but there are other calls as well. I am not sure if there is an API for location creation. If this is something that you wish to pursue, you may post your question to the BIM 360 API Forum.
Don
Don Simpson
Technical Support
anil_mistry
Autodesk Support
Autodesk Support
Hi @laura.smithPBW52,
I'm just checking in to see if you need more help with this. Did the suggestion that @don_simpson provided work for you?
If so, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Anil Mistry
Technical Support Specialist
