BIM 360 Field Forum
Welcome to Autodesk’s BIM 360 Field Forums. Share your knowledge, ask questions, and explore popular BIM 360 Field topics.
Accidental Selection on Checklist
2 REPLIES 2
812 Views, 2 Replies
On checklists if you accidentally select a response pass/fail, yes/no, etc. is there a way to unselect or cancel the selection you made? I have not performed  that Q&A yet, and I want to remove the answer I put in, but I cant find a way to do that
Tags (1)
2 REPLIES 2
james.l.bryant
Hello @Anonymous,
The latest BIM360 Field iPad App version allows a member to change a Response from +,-, n/a or from True, False, n/a.or from Pass, Fail, n/a.  It is designed with mind that each question within a Checklist needs a response, if response doesn't pertain then n/a should be selected.
If you have switched to another checklist or module and have found you need to change a response in prior checklist member may switch back to the checklist in Sync Settings>Upload>Right Arrow.  You can then see all pending records waiting to upload, simply select the prior checklist and change the answer as needed.
If you have an idea you feel would be beneficial to the community please share it with us at Ideas.   Thank you
James L Bryant
Autodesk Support Team
Contact Autodesk |
This isn’t a solution, we need to be able to uncheck the selection so the checklist shows it is not completed yet. With something selected it will show 100% and could be missed
Technology Administrators
